PCR2213 is equipped with electronically balanced inputs and outputs which also function unbalanced inputs
and outputs. The cross-feedback circuitry recognizes the connection of unbalanced loads and compensates 6
dB level difference when one of the signal is shorted to the ground.For connecting with unbalanced source to
the input of PCR2213, connect PIN 2 of XLR connector to the source signal and the PIN 1 and 3 of XLR
connector of PCR2213 to the source ground.
For connected with unbalanced load to PCR2213, there are 2 possible wiring methods:
(1): Connect PIN 2 of XLR connector to the load input, and connect PIN 1 of XLR connector to the load ground.
(2): Connect PIN 2 of XLR connector to the load input, and connect PIN 1 and 3 of XLR connector to the load
ground.
Znači u prvom slučaju se pin jedan spaja na masu rca konektora a pin tri ostaje u zraku, a u drugom slučaju pinovi jedan i tri idu na masu. Što mislite da je bolje? Osobno me je strah brujanja... a možda je i svejedno...
