kako odabrati driver - kako odabrati tip kutije
Re: kako odabrati driver - kako odabrati tip kutije
PostPostao/la yoke » Pon vel 24, 2014 3:43 pm
nisam siguran dali je pravi nacin...nekako mi je ostalo u sjecanju da je bilo jos nesto bitno...idem potraziti...ali evo za prvu ruku
Next we need to look at the Qts of the driver which is defined by its moving mass, the springiness of the suspension and the electrical damping from its magnetic system. Again, for a speaker in an enclosure, we would normally select a Q > 0.3 for a closed box speaker and a Q < 0.5 for a reflex design.
For an Open Baffle speaker using a passive crossover we actually require a driver with a high Qts. A Qts > 0.77 will mean that the amplifier will find it easier to drive the speaker as the frequency becomes closer to the system resonance. By careful choice of resonant frequency we can use this to extend the response below the baffle cut off frequency.
kopirano iz ovog teksta...
http://www.hi-fiworld.co.uk/loudspeaker ... rt-15.html" target="_blank
PostPostao/la yoke » Pon vel 24, 2014 4:07 pm
natjerao si me da se dignem iz kauca i da kopam po knjizi...
closed box...
-low free air resonace fs
-relatively high cone mass
- long voice coils
- Qts greater then 0.3
. potreban je veci linearni hod jedinice nego za bas refleks (ako se ne varam)
bass reflex
-Qts 0.2-0.5 obivno daju o.k. rezulatae
- imaju potrebu za manjim hodom
- less cone mass
po Vance Dickanson
Zadnja izmjena: yoke; Pon vel 24, 2014 4:26 pm; ukupno mijenjano 2 put/a.
PostPostao/la beboni » Pon vel 24, 2014 4:08 pm
audio kutak napisao:..... koji parametar od svih onih TS-parametara, ukazuje na volumen kutije
a koji ukazuje na to jel bolje BR ili TL ?
i molim kratki odgovor jer mi je i mozak.... kratak ovih dana...
ako je Qts(krutost kretnog sistema) veći od 0.4 onda kompresija ,TL ili aperiodična kutija.....takvi driveri uglavnom imaju manji magnet i krući ovjes .
ako je qts manji od 0.4 onda BR kutija,možda čak i horna ili onken.ako je krutost kretnog sistema iznad 0.77 onda je pogodno za tablu iliti open baffle ali obično jeftiniji driveri sa takvim t/s parametrima imaju mali xmax pa relalativno lako dolazi do mehaničkog ograničenja kretanja zavojnice po rasporu magneta i dolazi do izobličenja a ponekad i do oštećenja zavojnice.
(ovo je sve malo generalizirano i teško je to objasniti u 2-3 rečenice)
nego,ne treba tebi cijela nauka da napraviš zvučnike,tebi treba dobro razrađen projekat sa driverima koji koštaju do 200eura.
moj prijedlog je projekat mindstorm sa monacor sph176 i dt107 ,jednostavan,provjereno dobri driveri i jednostavna skretnica što omogućuje kupovinu boljih mkp folija i ofc špula
http://www.hifi-selbstbau.de/index.php? ... &Itemid=75" target="_blank" target="_blank
http://www.lautsprechershop.de/index_hi ... /ct213.htm
beboni
Postovi: 285
PostPostao/la audio kutak » Pon vel 24, 2014 4:45 pm
hvala dečki.... ide se u proučavanje materije....
da li tko ima kakav prijedlog sa Dayton driverima? da li je itko radio sa njima?
PostPostao/la audio kutak » Pon vel 24, 2014 6:13 pm
evo da stavim sliku par dizajna koji mi se sviđaju
pva dva su 2-stazni a treći je širokopojasni
najviše bih volio neki prijedlog prvih kutija, sa nekim 16-17 cm basevima... uglavnom je kutija dublja nego šira i
visine nekih 40 cm...
za srednje može i Cheap Trick CT 213 kao što je beboni predložio ali bih volio neke druge drivere
za zadnje širokopojasne bi došla u obzir recimo Dayton ili Gradient Axis serija drivera
moja namjera je napraviti zvučne kutije i uživati u muzici.... ne bih gradio ništa više.
PostPostao/la stressman » Pon vel 24, 2014 7:22 pm
A za prvu gradnju si baš našao kutiju poput prve... :)
as vintage as it gets
stressman
Postovi: 433
PostPostao/la audio kutak » Pon vel 24, 2014 7:41 pm
a što mogu kada mi se jaaaaakkoooo sviđa?!
uostalom, imamo mi crvenog tu na forumu.... ;)
PostPostao/la stressman » Pon vel 24, 2014 7:44 pm
Djeda mraza?
stressman
Postovi: 433
PostPostao/la Schultz » Pon vel 24, 2014 7:45 pm
LOL.... :mrgreen:
PostPostao/la yoke » Pon vel 24, 2014 7:45 pm
prvi tip kutije je vjerojatno i najbolji..najkruci...
ako ides na bas refleks
ili kompresiju...
za transmisiju bi trebala lamele biti postavljene okomito umjesto horizontalno...
(takav tip kutije sam ja radio)
ali ces potrositi hrpu materijala...
nekoliko puta vise od ''obicne'' kutije...
skuplje ce te doci drvo od drajvera...radije bi obrnuto...jer mi to bas nema smisla...
druga stvar je sam oblik...
ili ces napraviti sablonu pa sam glodalicom to raditi...hrpa posla...ali izvedivo
ili ces dati nekome na CNC
dodati trosak...
nek ti je u pitanju sperpoloca od breze 19mm, visna kutije 40cm, to ti je oko 20lamelax2, 40komada
s tim da se treba obraditi unutarnja i vanjska strana...
da se razumijemo ja bi to radio sebi...to sam planirao napraviti za raal/satori...ali nebi se zafrkavao ukoliko ce me drveni dio izaci 3x skuplje od samih drajvera...kao sto sam napisao, da je obrnuto onda super ;)
doduse takav oblik se moze dobiti i od jednog komada MDFa...onaj koji se krositi za zaobljene stranice...s utorima...pa se samo lagano savine i zaljepi....
ma sve se moze...
prvo se ti odluci za kakvu konfiguraciju zelis
- kompresiju
- basrefleks
- transmisiju
dvosistemac, FR....
a kutija je zadnja na redu...
:mrgreen:
